BIOLOGY
A-01
Krejci |
2D and 3D X-ray Fluorescence Microscopy of Strontium Uptake and Mineralization in Green Algae |
A-02 |
Monaenkova |
Butterfly Proboscis: Combining Drinking Straw with Nanosponge to Drive Evolutionary Diversification
A-03 |
Robison |
Mirco-SXRF Imaging of Transition Metal Distributions in the Brain of Rats after Chronic Mn Exposureand Healthy Controls
A-04 |
Henning |
Ultrafast Time-resolved Crystallography at BioCARS |
A-05 |
Janaswamy |
Time-resolved X-ray Fiber Diffraction at BioCARS Demonstrates the Dynamic Process of Ion Exchange in Crystalline Polysaccharide Matrices
A-06 |
Tietjen |
Structural Basis for Immune Recognition of Phosphatidylserine-containing Membranes Examined via Specular X-ray Reflectometery
A-07 |
Miller |
Investigating Microbial Biofilm Structure on Complex Substrates
A-08 |
Davis |
MiniXS Spectrometer for Mn Kβ Analysis of Samples with Sub-micromolar Mn Concentrations
CHEMISTRY
A-09 |
Halder |
Pressure-induced Sequential Orbital Reorientation in a Magnetic Framework Material
A-10 |
Lobo |
In Situ Characterization of Catalysts at 9-BM: Obtaining Insight through Combined IR and XAS Spectroscopies |
A-11 |
Zhao |
Multi-step Mechanism for Silver Particle Growth on a Porous Zeolite: A Time-resolved Pair Distribution Function Study
A-12 |
Bolin |
Soft X-ray Energy Research at APS Beamline 9-BM |
A-13 |
Focia |
Structure/Function Studies of Diquaternary Depolarizers Complexed with Cucurbituril
A-14 |
Alperovich |
Ruthenium L2,3- edges XANES Analysis of Water Oxidation Catalysts
CONDENSED MATTER PHYSICS
A-15 |
Yang |
Presence of a (1 x 1) Oxygen Overlayer on Capped and Bare ZnO(0001) |
A-16 |
Karunaratne |
Fast CCD Area Detector for X-ray Photon Correlation Spectroscopy Measurements from the Diffusion of Concentrated Alpha Crystallin Suspensions
A-17 |
Antonio |
Electronic and Structural Studies of Zircon under Pressure
A-18 |
DeCaro |
Microscale Domains in Langmuir Monolayers
A-19 |
Bera |
Crystal Structure of Solid Helium in Vycor Glass |
A-20 |
Huang |
Phasing Heavily Strained Crystal in Bragg Coherent Diffractive Imaging
A-21 |
Withdrawn |
A-22 |
Giles |
Site-specific Magnetism of Eu8Ga16Ge30 Clathrate Compound Studied by XMS and XMCD
A-23 |
Stoica |
Correlating Thermo-elastic Transients and Ultrafast Spin Dynamics in Epitaxial Fe Films |
ENVIRONMENTAL & GEOLOGY
A-24 |
Song |
Mechanisms of Cd Sorption to Clay Mineral Montmorillonite (Na-SWy-2) Affected by Ionic Strength and Siderophore DFOB |
A-25 |
Rui |
Bio-reduction of Nanoparticulate Uranyl Phosphate |
A-26 |
Mak |
Using Non-negative Matrix Approximation to Study X-ray Absorption Spectra |
A-27 |
Stubbs |
Structure and Reactivity of the Uraninite (111) Surface
HIGH PRESSURE
A-28 |
Wang |
Studying the Pressure-induced Amorphization in Nano-Y2O3 Using High-energy X-ray PDF Technique |
A-29 |
Sinogeikin |
Supporting Facilities for Synchrotron High-pressure High/Low-temperature Research at HPCAT, APS |
A-30 |
Yu |
Structural Stability of EuNi2P2 under High Pressure |
A-31 |
Kong |
High-pressure X-ray Diffraction Study for Piezoelectric Pb(Yb1/2, Nb1/2)O3CPbTiO3 |
A-32 |
Gao
Effect of Temperature on Elastic Properties and Sound Velocities of Compressed Cementite |
INSTRUMENTATION
A-33 |
Beyer |
Simultaneous PDF and FTIR Measurements at 11-ID-B
A-34 |
Gao |
Development of a Polarization Analysis System for Resonant Inelastic X-ray Scattering |
A-35 |
Liu |
TXM-Wizard: A Software Package for System Control and Data Analysis of Transmission X-ray Microscope |
A-36 |
Chen |
An Early View of the Bionanoprobe |
A-37 |
Xu |
Mini-beam Collimator Applications at the Advanced Photon Source
A-38 |
Shu |
Optomechanical Design of the Test Beds for X-ray multilayer Laue Lens Development at the APS and NSLS-II
A-39 |
Fischetti |
Micro-focus Beamline at GM/CA CAT |
A-40 |
Ross |
Continuing Work on Pixel Array Style Detectors at the APS |
A-41 |
Kline |
A Flexible Approach Employing FPGAs and Microcontollers for Beamline Instrumentation at the APS
A-42 |
Rivers |
asynMotor: Enhanced Motor Support for EPICS |
A-43 |
Spence |
Upgrade of the High-energy X-ray Diffractometer 11-ID-C at the APS |
A-44 |
Fan |
High-efficiency SAXS/GISAXS/WAXS Instrument for the Laboratory: Rigaku S-Max3000
A-45 |
Finney |
X-ray Fluorescence Imaging at Beamline 8-BM
A-46 |
Mooney |
SoftGlue: A Run-time User-configurable FPGA in EPICS
A-47 |
Assoufid |
Development of Grating Interferometers for Quantitative High-energy X-ray Imaging and for Real-time Wavefront Monitoring
MATERIALS SCIENCE
A-48 |
Chapman |
Pair Distribution Function Studies of Battery Materials |
A-49 |
Khvostichenko |
A Microfluidic Platform for Studies of Phase Behavior of Lipidic Mesophases by Small-angle X-ray Diffraction |
A-50 |
Chen |
Tomography and In situ Time-resolved Imaging of Structural Evolution in Nanoporous Gold during Dealloying and Coarsening by Transmission X-ray Microscopy
A-51 |
Feng |
X-ray 3D Atomic Imaging of Pt Nanocrystals Supported on SrTiO3(001)
A-52 |
Zhu |
Time-resolved SAXS/WAXS Study of the Phase Behavior and Microstructural Evolution of Drug/Polymer Systems |
A-53 |
Uysal |
Reverse Self Assembly: (111)-Oriented Gold Crystallization at Thiol Monolayer Templates
A-54 |
Moonshiram |
Spectroscopic Characterization of the Water Oxidation Intermediates in the Blue Dimer Ru-based Catalysts for Artificial Photosynthesis
A-55 |
Stolzenburg |
Stresses in Ytterbium Silicate Multilayer Environmental Barrier Coatings
A-56 |
Yuan |
Strain Characterization and Modeling of Bone-implant System |
A-57 |
Tester |
Synthesis and Stabilization of Amorphous Calcium Carbonate within Liposomes
A-58 |
Leung |
Crystallization Induced by Electrostatic Correlations in Vesicles of Mixed-valence Ionic Amphiphiles
A-59 |
Juggernauth |
Investigation of the Gelation Kinetics and Gel Structure of Laponite-based Photorheological Fluids
A-60 |
Batzli |
Aggregation Behavior and Kinetics of Bovine Insulin |
A-61 |
Mowat |
Study of Nanoparticle Agglomeration in Ferrogels Using USAXS |
A-62 |
Karan |
XAS Structural Characterizations of Manganese Oxide “Electrocatalysts” for Li-air Batteries |
A-63 |
Borkiewicz |
In Situ Pair Distribution Function (PDF) and X-ray Diffraction (XRD) Studies of Various Cathode Materials -Optimization of the Electrochemical Cell for the Purpose of Operando Measurements
A-64 |
Sun |
Investigation of Magnetic Thin Films Using Polarization Dependent X-ray Absorption Near Edge Structure (XANES) Spectroscopy
A-65 |
Ribaud |
Synchrotron Powder Diffraction Simplified: The High-resolution Diffractometer 11-BM at the Advanced Photon Source
A-66 |
Zhou |
Probing the Fluid-Graphene Interface for Electrochemical Storage by In Situ Synchrotron X-ray Scattering |
NANOSCIENCE & NANOTECHNOLOGY
A-67 |
Wojcik |
Hard X-ray Zone Plate Fabrication at the Center for Nanoscale Materials
A-68 |
Han |
Structural, Optical, and Electrical Properties of N+ Ion Implanted ZnO Nanorods |
A-69 |
Shyam |
Insights into the Lithiation of Nano-sized alpha-Fe2O3: A Combined X-ray Absorption Spectroscopy and Pair Distribution Function Study
A-70 |
Sun |
Investigation of Lattice Dynamics and Nanoscale Thermal Transport in FePt/Ag Heat-assisted Magnetic Recording (HAMR) Media Films psec Time-resolved Using X-ray Diffraction (XRD)
A-71 |
Stepanov |
Characterization of Voids in Nanostructured RDX-based Compositions using Ultra-small-angle X-ray Scattering |
A-72 |
Li |
Shape Change of Nano Rods Heated by Ultrafast Laser Pulses |
A-73 |
Li
Synthesis, Characterization, and Catalysis of Apoferritin Encapsulated Au/Ag Core-Shell Bimetallic Nanoparticles
A-74 |
Lei |
Bridging the Materials Gap between Model Catalyst and Practical Catalyst: An X-ray Adsorption Study on Supported Ultrafine Pt-Pd Nanoparticles Synthesized by Atomic Layer Deposition
A-75 |
Lee |
Nanostructure Characterization for Single-site Heterogeneous Catalyst Templates by Small-angle X-ray Scattering
A-76 |
Suthar |
Nanopatterning of Hydrogel – Gold Nanoparticle Composite |
OTHER
A-77 |
Quintana |
Improving Communication of APS Operations Information Using Social Networking Tools
A-78 |
Ward |
Application of Cluster Analysis Methods to X-ray Fluorescence Imaging Data |
POLYMERS
A-79 |
Meznarich |
Structural Changes and Evolution in Pluronic F127 Solutions with Added Pharmaceuticals
TECHNIQUE
A-80 |
Cramer |
Synchrotron Mossbauer Microscopy - A New Imaging Modality |
A-81 |
Pan |
Iterative CT Reconstruction using GPU for Synchrotron Radiation
A-82 |
Gleber |
New Tools at XRF Microprobe Beamline 2-ID-E |
A-83 |
Schmidt |
New X-ray Reflectivity Environmental Cell Design for In Situ Studies of Radioactive and Atmosphere-sensitive Samples |
A-84 |
Burghardt |
X-ray Photon Correlation Spectroscopy During Homogeneous Shear Flow
A-85 |
Swoboda |
Femtosecond Laser for Synchrotron Applications |
A-86 |
Singhal |
Effect of Ionizing Radiation on the Modulus and Residual Strains in Bone |
BIOLOGY
C-01 |
Bae |
Cellular Translocation of Hydrogel Microstructures Fabricated by Optical Lithography |
CHEMISTRY
C-02 |
Shapiro |
A Photo-induced Kinetic Model for Size-dependent Effects in SERS of Bioinorganic Hybrid Systems
C-03 |
Russell |
Methane Catalysis by Pt and Pd Tetramers Supported by Carbon Nanotubes
C-04 |
Rankin |
Augmenting DFT-based Volcano Plot Analysis for Product Selectivity on Catalytic Transition Metal Surfaces: Understanding Direct Reduction of Oxygen to Hydrogen Peroxide
C-05 |
Liu |
Catalytic Transformation of Biomass Derived Compounds into Fuels and Chemicals by Noble Metals |
C-06 |
Khan |
Polyoxovanadate-based Open-framework Materials for Gas Sensing |
C-07 |
Chien |
Cross-sectional Scanning Tunneling Microscopy and Spectroscopy of Fractured Oxide Surfaces and Heterostructure Interfaces
C-08 |
Gao |
Epitaxial Graphene on Cu(111) and Hydrogen Desorption from Graphene/SiC(0001) |
C-09 |
Kalarickal |
Spin-lattice Relaxation Channels in La0.67Sr0.33MnO3 Thin Films and Superlattices
C-10 |
Eid |
Magnetoresistance in Lateral GaMnAs Devices with Nano Constrictions
MATERIALS SCIENCE
C-11 |
Proffit |
Platinum Interdigitated Electrodes for Measuring Transport in delta-Bi2O3 |
C-12 |
Cho |
Atomic-scale Investigation of Graphene Grown on Cu Foil and the Effects of Thermal Annealing |
C-13 |
Ocola |
Chemical Vapor Process of E-beam Resists for CNM Users
C-14 |
Yildirim |
Li Ion Diffusion Characteristics in TiO2 Polymorphs: Concentration and Morphology Role |
C-15 |
Chan |
Computational Studies of Silicon as Li-ion Battery Anode |
C-16 |
Zhang |
Model Catalyst Study of Pt Nanoparticles Supported on gamma-Al2O3 Single Crystals
C-17 |
Ng |
Self-assembled Cu Nanowire on Vicinal Si(001)
C-18 |
Latimer |
Vortex Physics in MoGe Thin Films Containing Periodic Hole Arrays |
C-19 |
Makarova |
High-aspect-ratio Polymer Nanofilters by Interference Lithography |
C-20 |
Smerdon |
Reversible Rectification in Sub-monolayer Molecular Heterojunctions |
C-21 |
Yitamben |
Molecular Motion Confined to Self-assembled Quantum Corrals
C-22 |
Lepak |
Electroplate-and-Lift (E&L) Lithography on Reusable, Patterned Ultrananocrystalline Diamond (UNCD) Templates for Rapid Prototyping of Micro- and Nanowires
C-23 |
Suzer |
Toward Atomic-scale Optical Probes with UHV Scanning Tunneling Microscopy
C-24 |
Tseng |
Improving the Etch Resistance of Electron-beam Lithography Resists Using Sequential Infiltration Synthesis |
POLYMERS
C-25 |
Deshmukh |
Solvation Dynamics in Thermo-sensitive Polymers: Molecular Dynamics Study |
TECHNIQUE
C-26 |
Deshlahra |
Polarization Dependent MEIRAS Study of CO Adsorption on Pt Nanowire Catalysts
C-27 |
Kharlamova |
Nano/microfabrication of Pt/Cr Electrical Contacts for Transport Measurements in Diamond Anvil Cells
MATERIALS SCIENCE
E-01 |
Alvarez |
In situ Study of Nanoparticle Growth in ZBLAN Glass |
E-02 |
Pan |
Evolution of Magnetic Domain Structure Induced by Interfacial Strain in CoFe2O4/BaTiO3 Epitaxial Heterostructures
E-03 |
Zeng |
Hydrogen Gas Sensing with Networks of Ultra-small Palladium-based Nanowires
E-04 |
Ma |
Nano-bubble Cavity Probed by Cathodoluminescence |
OTHER
E-05 |
Lu |
Overcharge Effect on Carbon Electrode for Lithium ion Batteries |
E-06 |
Chen |
In Situ TEM experiments of irradiation on CexLa1-xO1.5+0.5x Single Crystal
E-07 |
M’ndange-Pfupfu |
Tribological Investigation of “N3FC” Diamond-like Carbon Films Using In Situ TEM |
